I'm new to cypress products. I'm willing to adapt a board with a Cy7C64013C USB controller to new specifications.
First thing first : I need to find a way of programming it. I havn't found the hardware connection to use in its datasheet.
Also, is there a developpement Kit suitable for this componant?
thanks in advance.
Cyril
Please see  http://www.cypress.com/?id=170&rtID=107.
Prajith
Thanks for the information,
unfortunatly, the datasheet of the CY7C64013C didn't provided any information on which pins to use for the ISSP protocol.
Do I have to assume that as on the other component you joined, I have to use the P1[0] and P1[1] pins?
It seems unlikely that such an information wouldn't be diplayed in the datasheet.
Also, I'm still confused with starter Kits.
Cyril
 Cyril,
  Please see this link http://www.cypress.com/?rID=14317. You will have all the details here.
Prajith
