Dear folks,
         While performing GPIF FIFO READ/WRITE operation GPIFREADYSTAT which scans the status of RDYx signals always shows the value of 0x003f (which means all the RDY inputs are high, even after grounding the respective RDY input signal). what could be reason for this? Can any one suggest a suitable solution.
