I met a problem with devices of cy7c68013a and 24lc128.
I wrote a firmware and got two formats: .hex and .iic. After xxx.hex loaded into the RAM, the usb renumerated and worked well. But when I loaded the xxx.iic into the eeprom, the usb can't renumerate.
I assure xxx.iic was loaded into eeprom and the format is right. The first byte is 0xC2.
I don't know whether the program in eeprom wasn't loaded into RAM or loaded but not renumerated.
Development environment
1) I am using a Cypress FX2LP DVK.
2) Firmware is being used after modifying AN 63787 - EZ - USB ® FX 2 L 1.
Confirmed
1) We probed the I2C line and confirmed that it was receiving the signal.
2) Using Vend_ax example (FX 2 LP DVK), read from EEPROM using vendor command and confirm that the first byte is 0 x C 2.
I attach a hex and an iic file here.
thanks in advance
Hi Maeda-san,
We found that your program have an improper statement in the "Setup Data Available" interrupt.
Your code:
// Setup Data Available Interrupt Handler
void ISR_Sudav(void) interrupt 0
GotSUD = TRUE; // Set flag
EZUSB_IRQ_CLEAR();
USBIRQ = bmSUDAV; // Clear SUDAV IRQ
EZUSB_IRQ_CLEAR();
EZUSB_IRQ_CLEAR();
Could you please modify your code as follows? Then, it works.
Modified code:
void ISR_Sudav( void ) interrupt 0
EZUSB_IRQ_CLEAR( );
Hirotaka Takayama
