Hi Sir,
I follow SuperSpeed Explorer Kit User Guide_001-93186_A.pdf to do debug with EZ USB suite,but return me some error as below,please help to check.
44^error,msg="localhost:3333: \323\311\323\332\301\254\275\323\267\275\324\332\322\273\266\316\312\261\274\344\272\363\303\273\323\320\325\375\310\267\264\360\270\264\273\362\301\254\275\323\265\304\326\367\273\372\303\273\323\320\267\264\323\246\243\254\301\254\275\323\263\242\312\324\312\247\260\334\241\243\r\n."
(gdb)
45 monitor reset halt
monitor reset halt
"monitor" command not supported by this target.
&"monitor reset halt\n"
&"\"monitor\" command not supported by this target.\n"
45^error,msg="\"monitor\" command not supported by this target."
(gdb)
46 monitor mww 0xFFFFF014 0xFFFFFFFF
&"monitor mww 0xFFFFF014 0xFFFFFFFF\n"
65 load
load
You can't do that when your target is `exec'
&"load\n"
&"You can't do that when your target is `exec'\n"
65^error,msg="You can't do that when your target is `exec'"
(gdb)
66-exec-continue
66^error,msg="The program is not being run."
(gdb)
Leo
ispn:38621:1:0
l1:314:1:0
Hello Leo,
I tried to reproduce the problem at my end. (refer attachment).
To solve this issue you need to follow the steps from software setup (page: 36) of the document you mentioned in your post.
The configuration file arm926ejs_FX3.cfg need to be added.
The document you are referring is not the latest version.
Note: The path to directories will differ if you are using the newer SDK with this document
You can refer to Section 3.2 of EzUsbSuite_UG - Debugging with OpenOCD in the newer version of SDK 1.3.4 https://www.cypress.com/documentation/software-and-drivers/ez-usb-fx3-software-development-kit
Rashi
Rashi
Hi Leo,
- It seems that you using OpenOCD for denugging. Please Confirm.
- Can you share the prints from other console (Refer attachment)
- Are you following all the steps mentioned in the user guide that you pointed to in the post? Please confirm.
- If you are using OpenOCD what is the version? 0.8.0 version is recommended
If using Segger J Link Install latest J Link GDB Server software
Rashi
Rashi
Hi Rashi,
1. I haven't used OpenOCD ,my console prints as below
2. I followed all the steps mentioned in the user guide from page 39 to page 42.
Leo
Hello Leo,
Rashi
Rashi
