USB low-full-high speed peripherals Forum Discussions
brant123
First like given First reply posted First question asked
I met a following error on FX2LP-cy7c68013a. The project is designed as USB2.0 HS mode.
When Host sent NYET PID,  USB PHY has no any answer, sound card is closed.
However, FX2LP have no any interrupts with NYET, so how to deal with NYET?
The following photo is other UAC2.0 sound card. It answered ACK after NYET, so Host success to open sound card.
MallikaK_22
Moderator 250 solutions authored 500 replies posted 250 replies posted
As per USB spec, the NYET handshake packet is sent by the device when the endpoint cannot accept more data.
>> Please check the following KBA.
>> https://www.usbmadesimple.co.uk/ums_7.htm
Mallika
MallikaK_22
Could you please provide details of your system? I also need to look into the source code for analyzing the issue.
Please share the source if not confidential.
Mallika
brant123
Thanks for your reply!
Simply speaking, based on FX2LP, how to check out NYET which sent from Host?
MallikaK_22
Mallika
brant123
Thanks, Mallika.
My question is already solved. The root reason is that UAC device have not responded  for
AudioControl Requests, such as Sampling Frequency Control  and Clock Validity Control.
Thank you again for your time.
