mako_4822271
Hi.
We are interesting in implementing Serial MPEG-TS to USB bridge via Cypress CY7C68013 in our platforms.
We are also planning to purchase CY7C68013 evaluation board for testing. (FX2LP DMB-T/H TV Dongle Reference Design)
So, we need the following:
1. Where can we purchase the FX2LP DMB-T/H TV Dongle Reference Design?
2. Full Cypress CY7C68013 documentation including datasheet, AppNotes with full registers/hardware description, examples etc.
3. SDK or some reference project covering Serial MPEG-TS input interface for CY7C68013.
Thanks in advance.
Manfred
YatheeshD_36
Please refer to the below documents:
1. FX2LP DVK ISO: https://www.cypress.com/documentation/development-kitsboards/cy3684-ez-usb-fx2lp-development-kit
This contains the driver, examples, software and documents (TRM, datasheet, user guide etc) needed for development.
2. Application notes: https://www.cypress.com/products/ez-usb-fx2lp#tabs-0-bottom_side-3
IMPLEMENTING AN 8-BIT PARALLEL MPEG2-TS INTERFACE USING SLAVE FIFO MODE IN FX2LP Application note: https://www.cypress.com/documentation/application-notes-obsolete/an58069-implementing-8-bit-parallel...
This board is not available for purchase on cypress site.
Yatheesh
YatheeshD_36
Yatheesh
