abdullahnasir
First like received 5 sign-ins First reply posted
Hi All !
I am trying to run serial port 1 on my cy7c68013a as this is my hardware requirement and I cannot shift it to serial port 0. I had successfully initialized serial port 0 and am able to use uart at 9600 baud rate.
Can anyone help me in configuring the uart at same baud rate on serial port 1.
For refernece I had attached my code along.
MallikaK_22
250 solutions authored 500 replies posted 250 replies posted
Please refer to a similar thread: https://community.infineon.com/t5/USB-low-full-high-speed/FX2LP-CY7C68013A-Serial-port-1-configurati...
Please also let me know what is the issue seen when you are configuring for serial port 1.
Mallika
MallikaK_22
Mallika
