FX2 thermal problem!
not_A_quitter
First solution authored 5 replies posted 10 sign-ins
I’m working on CY7C68013A in one of my projects and I’v been facing a thermal problem where controller gets quite hot when I connect the usb cable. When the usb cable is unplugged the heat seems reasonable. Any thoughts on that will be appreciated?
Meghavi
250 replies posted 100 solutions authored 10 likes received
Please refer to this AN15456 EZ-USB_FX2LP_Hardware_Design and let us know if you are following all the guidelines.
Meghavi
Meghavi
Meghavi
Thanks Meghavi,
Thats actually what i'm working on right now. After reading this app note i found out that i didn't have a VBUS sensing mechanism in my design; a standalone power design independent of usb VBUS. So i'll try that and i will report my findings for general knowledge.
not_A_quitter
I got another controller from another supplier and its working just fine. The problem had to do with that particular batch of controllers?
Yes, this can be a reason. Can you please confirm how many parts you found the same issue? Also, please add the VBUS sensing mechanism for your design.
Meghavi
At least three.
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
Could you please provide details on where did you purchase these silicon from. Also, please attach a screenshot of the markings on the IC.
Mallika
