I'm new to the FX2. Does anyone know where I can find an example code for SPI master for the FX2?
I also need the USB host code in C Linux to drive this SPI interface.
Hay
Thanks, Madhu!
The document says it's obsolete - is it still good to use?
Also, do you have access to the companion Linux host USB c code for that SPI f/w?
hay
