FX2 Bulkloop firmware using SDCC
DaBr_659386
10 replies posted 10 questions asked 5 replies posted
To avoid re-inventing the wheel, has anyone ported the FX2 Bulkloop example from Keil to SDCC / Eclipse to run with CyUSB.sys on Windows that they could share ?
Dave
DaBr_659386
In case anyone else has the same question, here is a good start:
http://www.cypress.com/documentation/application-notes/an61345-designing-ez-usb-fx2lp-slave-fifo-int...
You can already get it if you get the FX3 dev kit. It contains a version of Eclipse that has all the necessary tools (except for SDCC itself, you need to get it yourself).
You can create a new project using the BulkLoop as an example.
I did a video on how to set it all up (it's not very good but hopefully it'll get you started.)
https://www.youtube.com/watch?v=bpVk98my2yw
Ho-Ro
5 sign-ins First question asked First reply posted
Even if it is not the bulkloop example, this may help anyone (even after a few years) who is looking for a Linux startup point:
GitHub - shenki/cystream: Cypress EZ-USB FX2 CyStream with SDCC
Martin
