We use CY7C68013A-56PVXC as USB transmission scheme for communication between PC and industrial control board. When plugging in the front USB port of the host computer, the communication will be wrong, while the back USB port communication is normal.
In the other board that use CYC68013A-100AXC have no error.
The error code is:
USTS c0000011
the log picture as below:
>> It seems like you are using a custom board. Please check if the hardware guidelines are being followed as explained in the App Note: https://www.cypress.com/file/135006/download
>> Between testing for the 2 boards, are the test environment and PCB layout the same? I mean did you use the same USB cable for both the boards?
Mallika
