Deeps_bang
First like given First reply posted First question asked
Hi Team,
Working Env: Windows 10 Pro
Have installed FX3SDKSetup1.3.4 and referring Getting Started with FX3 SDK PDF to install and test the project.
When i import 'USBBulkLoopAuto' project and debug...its showing Sematic error at uint8_t, uint16_t..and so on .
the same error not shown when i import other project 'GpiftoUSB'.
Project->C/C++ index-> resolve unresolved includes ....didnt work
what am i missing..??
AliAsgar
250 solutions authored 750 replies posted 50 likes received
Could you try Project -> C/C++ index -> Freshen all files, then you can clean the project and then close and open it again. Try building the project after doing this. If you still face the issue, please send a snippet of the error.
AliAsgar
AliAsgar
AliAsgar
Deeps_bang
Hi AliAsgar,
Thank you for the solution.
Need one more suggestion.
In our on going project need to read Image sensor (AR1335) data --MIPI CSI-2 interface, EZ-USB CX3 board. In SDK which is the best suitable example for this task.
Deeps
AliAsgar
Hi Deeps,
We do not have any firmware examples with AR1335+CX3. Please go through the KBA for details on how to create a firmware for CX3 for a particular sensor : https://community.infineon.com/t5/Knowledge-Base-Articles/Steps-to-Setup-up-MIPI-CSI-Camera-Solution...
AliAsgar
