NXTY_Nishinaga
Level 4
Level 4
Distributor - NEXTY (Japan)
10 solutions authored 25 replies posted 5 solutions authored
Do you have a driver of EZ-USB FX2 for Windows10?
I have used EZ-USB FX2 (CY7C68013-128QFP)for Windows7.
This time, I would like to change the host PC from Window7 to Windows10.
(VID: 0x0547,  PID: 0x1002)
These VID and PID don't seem to be included in the default cyusb3.inf
installed with the EZ-USB FX3 SDK.
Nishinaga.
Hi Nishinaga,
You can use the cyusb3 driver that is present in the FX3 SDK and it has default VID/PID. The VID(0x0547) and  PID(0x1002) you mentioned for your device is customized and not documented the CyUSB.pdf. To use that VID/PID, you need apply for a driver resell.
We do not recommend to use any other website to get the driver except our official sources.
Meghavi
JayakrishnaT_76
cyusb3 is a vendor driver supplied by Cypress/Infineon. It can be used to bind to USB device having VID/PID combination present in the cyusb3.inf. The default cyusb3.inf contains only Cypress VID (0x04b4) and PID combinations in it. The list of all supported VID/PID combinations is already documented in Page 5 and 6 of the document CyUSB.pdf that comes along with FX3 SDK. This docuent can be found in the followng location after installing FX3 SDK:
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc\SuiteUSB
If the driver should support a custom VID/PID combination, then you can apply for a driver resell. Please let us know if you have a VID for your organization. The document mentioned above provides more details on the driver resell procedure. You can also refer to the following KBA which documents the FAQs related to Driver resell:
https://community.infineon.com/t5/Knowledge-Base-Articles/Driver-resell-and-Driver-signing-FAQs-KBA2...
Jayakrishna
NXTY_Nishinaga
Level 4
Level 4
Thank you very much for your quick response.
I have been using EZ-USB FX2 with Windows7 PC for a long time.
I found this VID(0x0547) and  PID(0x1002) listed in cyusb.inf installed on Wndows7 PC.(show below)
; Installation INF for the Cypress Generic USB Driver for Windows 98ME/2000/XP
[Cypress]
%VID_0547&PID_1002.DeviceDesc%=CyUsb, USB\VID_0547&PID_1002 ★
%VID_04B4&PID_8613.DeviceDesc%=CyUsb, USB\VID_04B4&PID_8613
What I want to know is if there is a driver available for using EZ-USB FX2
on Windows10.(Without inf file customization.)
Also, I found the driver on the following site, but is it unrelated to your company?
https://urldefense.com/v3/__https://treexy.com/products/driver-fusion/database/universal-serial-bus-...
Best Regard,
Nishinaga.
NXTY_Nishinaga
Level 4
Level 4
Thank you very much for your answer.
I have been using EZ-USB FX2 connected to Windows7 for many years.
This VID(0x0547) and  PID(0x1002) is listed in the cyusb.inf installed to Windows7 PC.
---- cyusb.inf ----------------------------------------------------------------------------------------
[Cypress]
What I want to know is whether you can provide an EZ-USB FX2 driver that can be used in Windows 10 without customizing the inf file and cat file.
Also, I found the driver at the following site, but is it irrelevant to your company?
Nishinaga.
Hi Nishinaga,
Meghavi
