Does someone have the TD_Init() code for autoout?
I configure the antoout mode as follows:
Typically, a FIFO is configured for Auto-Out mode as follows:
1. Configure bits IFCONFIG[7:4] to define the behavior of the interface clock.
2. Set bits IFCFG1:0=11.
3. Reset the FIFOs.
4. Set bit EPxFIFOCFG.4=1.
however,I send 1024 bytes with Cyconsole.exe , the out transfer are failed.
I remember that in the AUTO-IN mode ,i set the AUTOINLENH:L. But in the AUTO-OUT mode, i can't find the relevant register.
anyhow, does someone have the TD_Init() code for autoout?
See the associated project available with this AN http://www.cypress.com/?rID=43046, here EP2OUT has been configured as AUTOOUT.
Prajith
hI,Prajith
I test the source code ,it works well. Thank you.
