Does Cypress have a USB Transceiver to replace CY7C68003?
GrCa_1363456
Level 6
Level 6
50 likes received Beta tester First comment on KBA
It appears Cypress has EOL'd their only USB Transceiver device, CY7C68003.
Cypress' USB Transceiver web page exists without any apparent link to any products https://www.cypress.com/products/usb-transceivers
Does Cypress have a recommendation for customers interested in designing in a basic USB Transceiver?
Related:
A similar question remains unanswered @ Transceiver Choice
Another post concluded that Cypress has no alternative @ CY7C68003 24-pin QFN
Greg
Sananya_14
Hi Greg,
We currently dont have a direct replacement part for TX2UL. Could you please let me know your application so that I can check for any other part?
Sananya
Sananya_14
Hi Greg,
Sananya
Sanaya,
CY7C68003 was ideal for applications where a USB controller exists in a space constrained application that needs an external connection to USB. Cypress appears to have some higher end options with more functionality. Cypress’ has serial bridge controllers @ https://www.cypress.com/products/usb-serial-bridge-controller as well as a transceiver with embedded host/slave controller @ https://www.cypress.com/products/sl811hs.
Greg
Hi Greg,
Yes there arent any parts which are only a USB transceiver. You could also check FX2LP which is similar to SL811HS and is a high speed controller with a transceiver. Please see if any of them are suitable for your application.
Sananya
