Sep 01, 2020
04:49 PM
Sep 01, 2020
04:49 PM
Can I use a development kit CY3684 to debug the firmware for CY7C68014A-56PVXC? The development kit uses the CY7C68013A-128AXC which also has access to the serial port for the KEIL debugger. I don't need all the functionality of the 128 pin part and the power consumption is also a benefit is the reason to use CY7C68014A-56PVXC
Thanks in Advance!
Chris
11:27 PM
Sep 01, 2020
11:27 PM
Hi Chris,
Yes, you can. But you should move your code into the CY7C68014A-56PVXC project after debugging, they are not pin-to-pin devices.
11:27 PM
Sep 01, 2020
11:27 PM
Hi Chris,
