I am using the Xilinx Zed board on a Window's 7 PC but it needs the UBS driver but I can find it for download.
The Zed board uses https://www.infineon.com/dgdl/Infineon-CY7C64225_USB-to-UART_Bridge_Controller-DataSheet-v08_00-EN.p...
I did find this CyUsbUART : https://www.infineon.com/cms/en/design-support/tools/configuration/usb-uart-config-utility/?utm_sour....
I also found this but no links to the driver:
Any assistance is appreciated,
David
Hi Devid,
Please download the serial SDK from the below link.
install the SDK, drivers will be available at the below path
C:\Program Files (x86) \Cypress\USB-Serial SDK\Cypress USB-Serial Driver\DriverBinary
CY7C64225 part is obsoleted we are not recommending using this part.
you can use below part for USB Serial bridge.
Varun Narolkar
