- Email to a Friend
Does anyone work on EZ USB FX2LP? Basically, I wanted to do FIFO Read and Write transactions. When I loaded the precompiled firmware the board disconnected and connected again which is supposed to do. But the driver of the FIFO example comes with a yellow mark in the device manager. I search for the driver but didn't find it. As per documentation, the driver installed automatically after loading the firmware but it didn't do.
When I compile the files again and load the firmware then it does nothing. This means instead of loading the precompiled version of firmware I compile it again in Keil.
Can anyone purposed a solution to this problem?
Please see the attached file for precompiled firmware.
- Email to a Friend
Hi Yazan,
Since you are new to FX2LP, can you please first start with the following App Note: https://www.infineon.com/dgdl/Infineon-AN65209_Getting_Started_with_FX2LP-ApplicationNotes-v10_00-EN...
It also has some examples as well as step-by-step instructions.
Kindly go through it once and let me know if you have any queries.
Mallika
- Email to a Friend
Please confirm if before loading the firmware, how did the device enumerate.
What firmware did you program and how did you program?
Mallika
- Email to a Friend
I am new to this board. I load the FX2_to_extsyncFIFO example to fx2lp. I load the firmware using the cypress control center.
You can see the video how I load the firmware. And compile same program in keil.
I compile on keil uv2 because I don't have keil uv5 licensed.
Video Link
https://drive.google.com/file/d/1bBDr17ad4qmunvCiQGdvFeljGSFrzTpv/view?usp=sharing
Yazan
- Email to a Friend
Hi Yazan,
Mallika
