 Does anyone make applications that use CyUSB.sys and DIrectShow?
I want to make video application using standart driver CyUSB.sys and videoout throught DirectShow
 Hi Leva,
I try to connect a camera based on CyUSB.sys with the capture filter of directshow application and i dont know how to proceed. if you have any information that could help me, please let me know.
thank you 🙂
 I found this on web with Direct show. It is in Chinese, but try translating. I do not know if this might help you or not. But in case if it helps you. Just try this out: http://read.pudn.com/downloads166/doc/765512/%E5%9F%BA%E4%BA%8EUSB2.0%E5%92%8CDirectShow%E7%9A%84%E8...
Gayathri
