sesk_4098801
Hello!
A  few  years  ago, I wrote an C++ application for Windows - use CY68013, CyAPI-based, and it work good.
And now, after migrating from Visual Studio 2015 to Visual Studio 2017, my application (for CY68013, CyAPI-based) can not build anymore!
I've got the error message:
1>CyAPI.lib(CyAPI.obj) : error LNK2019: unresolved external symbol _sprintf referenced in function "public: void __thiscall CCyUSBDevice::UsbdStatusString(unsigned long,char *)" (?UsbdStatusString@CCyUSBDevice@@QAEXKPAD@Z)
It seems that problem is into CyAPI.lib.
How can I fix it?
Thnx.
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
- Please check if you have added the 'legacy_stdio_definitions.lib' in the "Linker" input properties (See below image.)
- If you still face the issue, kindly, share the project for me to check. In case you feel the project is confidential, send it over the private message option.
Srinath S
SrinathS_16
Srinath S
Thank you very much!
It helped!
