I am trouble-shooting intermittent read errors from the custom design using 68013a at 480Mbps USB transferring data to Windows PC-based application using 3.4.7 Cypress driver and .net library. The problem occurs rarely - once per 1..5*10e7 packets control transaction ctrlEP.XferData() returns false almost immediately or after few (0-5) milliseconds. Surely I have tried obvious remedies such as using better (or shorter) USB cable, different PC and different USB2.0 port but the problem is persistent.
- What is the re-transmission policy of the control transactions in the CyUSB driver / .net library  (how many retries are allowed before declaring the failure)?
- Is any way to change the re-transmission policy?
- Any other ideas/suggestions are greatly appreciated
Alex
Sananya_14
Hi Alex,
Please update the driver to the latest version from http://www.cypress.com/file/322371 and .net library from FX3 SDK at http://www.cypress.com/file/139276 . Check again after updating and let us know if the errors still occur.
Sananya
Sananya_14
Hi Alex,
Sananya
