- Email to a Friend
We intended to configure CY7C65213 as self-powered mode. Other than the schematic connection shown below, the datasheet also says
"Using the configuration utility, the configuration descriptor in the
CY7C65213/CY7C65213A flash should be updated to indicate
that it is self-powered."
My question is: Can the internal flash be accessed and set after the circuit is connected this way? Especially the default power mode in the flash is bus-powered. Thanks.
How does the power mode in the flash affect the chip behavior? Is it just for information purpose, or it changes the chip's function?
- Email to a Friend
Please let us know if you have referred to this KBA USB-Serial: Programmed Configuration not Updated i... - Infineon Developer Community
Rashi
- Email to a Friend
Rashi
