Hi every one, I Have designed a PCB with USB interface using CY7C68013A chip. It work very well on most notebooks. But in one case this problem occur in driver installation:
The note book is Lenovo G-50 and OS is windows 8-32 bit.
What should I do for solving this problem?
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
Please try uninstalling the driver and re-installing it with the latest version 1.2.3.20 from the below link.
http://www.cypress.com/documentation/software-and-drivers/ez-usb-fx3-software-development-kit
Srinath S
SrinathS_16
Srinath S
Thanks for your answer, Srinath S
what i should to to with SDK? In other nootebooks that the device work fine, the only work that i do is to install driver from 'Device Manager'.
As the error message displays, this can be due to corrupted/missing drivers. Please make sure that you download the driver from the mentioned link and do not modify the files present in the driver package folder.
Srinath S
