hie everyOne,
I have one device having FX2LP for usb connectivity. and i have developed one code using CyUSB utility in Linux which displays the device descripotor of the device and logs it in log file.
but for this i have run the code. to get this. Actually i wanted to do like whenever i plug my device the code i have written should run automatically n logs the descriport in file.
i know this can be done with kind of daemon process i am trying  but i am not able to understand the things how to do this
please do rply i want to make it happen (i am working in linux)
Thanks & Regards
Rohan
        Dear sir, please help me in this i have tried to run the script also in the .rule file but it didnt worked like, KERNEL=="*", SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ACTION=="add", ATTR{idVendor}=="04b4", MODE="666", TAG="cyusb_dev", RUN+="/usr/bin/run_code.sh A" KERNEL=="*", SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ACTION=="remove", TAG=="cyusb_dev", RUN+="/usr/bin/run_code.sh R" thanks & regards rohan
hieee
now i am able to run the .sh through udev .rule file using RUN+=
how can i run (or invoke to run) bigger codes through the .rule in udev. in cyusb utility
because the script we are running through udev rule has to get detach itself, we can not run long execution
how to over cum this thing in cyusb
please do rply me, Need ur help
regards
rohan
hieee sir,
anyone please help me in this & daemon process in cyusb linux sdk
Thanks & regards
Rohan
Hi Rohan!
I have same problem. I need to write deamon which will be download firmware to FX2 RAM after connection to USB port.
Did your solve this? Could you, please, share your solution?
Thank you!
Alexander
 Hi
Did you check out FX3 SDK for Linux?
The host app Control Center detects the plugging and unplugging of cypress devices and displays in the host app accordingly.
Please check the related code.
thanks
Nikhil
