hi:
Do I want to support Linux and android with CY7C68013 to provide an example code for UVC?
thanks
Please refer to this KBA Linux support for FX2LP and other USB Peripherals.
Yatheesh
Please confirm that you have referred to the firmware attached with these two KBA:
USB2.0 Camera Interface Using FX2LP™ and Lattice CrossLink FPGA - KBA222479 - The attached firmware is tested on CameraFi - USB Camera / Webcam application on Android phone
Interfacing FX2LP™ with Image Sensor – KBA95736
Rashi
Rashi
hi: RashiV
We use this way cy7c68013A to connect sensors directly. It's normal under windows. Now we need to solve the support under Linux and android, so we want the firmware code。Under Windows, we use the driver mode.
Yatheesh
