I've been given the task of changing some usb buttons, and testing indicates that they use the enCoReII Keyboard RDK. Digging around, the documentation here indicates I need a PSoC MiniProg programmer and a 5-pin to USB interface adapter. Looking around further, I can't find any 5-pin to usb interface adapters and i'd rather not have to make one, so would I be able to re-program the button using the PSoC MiniProg 3? If not, is there another alternative?
SrikanthD_56
First question asked First comment on blog 100 replies posted
You can use MiniProg3 to program the EnCoRe II device, but you still need the 5-pin to USB interface adapter to do so. I don't think there is an alternative for this.
Schematic for 5-pin to USB interface adapter can be found here.
Hmm, I see. Do you have any suggestions on where I should purchase the components to make it? This is really my first foray into this type of stuff, so i'm very inexperienced. Thank you for your response!
Part number for 5-pin to USB interface adapter is CY3655-PLG. For convenience, you can try procuring one online (not sure of the availability in your region though).
