MSSa_1300736
First like given
I want to take advantage of USB 3 power that is near 7W. But my design contain Fx2LP. So is it posssible to connect Fx2lp wit usb 3 receptacles? I am ok with speed limited to 480 Mbps as per USB2.0 specifications.
YatheeshD_36
Yes, FX2LP works well with 3.0 ports. But the speed will be limited to 480 Mbps (High Speed).
Yatheesh
YatheeshD_36
Yatheesh
Will there be any firmware mismatch issue? Fx2 and Fx3 has different firmware examples.
Yes there will be a firmware miss match between FX2 and FX3.
FX2LP uses 8051 while FX3 has ARM core.
Yatheesh
