AlLu_1238711
Dear Technical Support,
as described in the PDF Chapter 3 of the Cypress CyUsb3.sys Programmer's Reference, I would like to start the Driver Resell procedure in order to have a customized driver for my hardware (based on FX2LP Cypress USB) with a dedicated .inf file. in the documentation it is written that I:"need to contact Cypress Technical Support and create a case(https://www.cypress.com/
support) with the below information to initiate the driver resell process.
1. Company details.
2. INF file with your devices VID/PIDs. "
I prepared all this info but which is the right way to contact cypress Techicanl Support and create the "case", is by this community or may I have a direct email contact with a Cypress representative?
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
Please share your INF file and the Microsoft Account Dashboard name to srinath.s@cypress.com.
Srinath S
SrinathS_16
Srinath S
SrinathS_16
The driver resell has been completed. Kindly, check your Microsoft Account Dashboard.
Srinath S
