CY8C68013A 's issue of Cypress FX2LP No EEPROM Device?
David_Zhang
Level 5
Level 5
Distributor - Arrow(GC)
First comment on blog First like received 50 sign-ins
hi   CYPRESS:
    When i use  cypress  CY8C68013A to do myself tool, when i install the kit, it show Cypress FX2LP No EEPROM Device? in my sch , the iic connct to the at24c02 and sch has been attached ,  when i use USB Console it show the erro, so if the at24co2 has issue or other issue ?
Sananya_14
From your schematic, it isnt clear if your EEPROM address is 0x51 or 0x50 based on the A0 pin. Please clarify the same?
Since your EEPROM size is of 32 x 8 bytes, it requires one-byte addressing and hence is considered to be a small EEPROM. Kindly connect the address lines set to 0x50 and the try the transfer on the Console. You could also refer to the KBA for more details.
Sananya
Sananya_14
Sananya
David_Zhang
Level 5
Level 5
hi  Sananya:
       in  my PCB, i  use small eeprom  device, at24c02,  both  A0-A1 connect to GND, so the address is, so  my hardware is write,
which i should to change??
If all the three address lines A2,A1,A0 are pulled so ground, the 7-bit address will be set to 0x50 and the write should work when you choose Small EEPROM option on CyConsole to download firmware.
Sananya
David_Zhang
Level 5
Level 5
Tks, the issue has solved;
发件人: SananyaM_56 <community-manager@cypress.com>
发送时间: 2019年7月16日 13:36
收件人: David W Zhang <DavidW.Zhang@arrowasia.com>
主题: Re: - CY8C68013A 's issue of Cypress FX2LP No EEPROM Device?
CAUTION: This email originated from outside of the organization. This message might not be safe, use caution in opening it. If in doubt, do not open the attachment nor links in the message.
<https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cypress.com&data=02%7C01%7Cdavidw.zhang%40arrowasia.com%7Cbb8c6c45031e41384c8808d709af6da7%7C0beb0c359cbb4feb99e5589e415c7944%7C1%7C0%7C636988521372890245&sdata=oYJ4os8vPwNUXEbOe8S%2FspAIDoQPemJGB16t8PMQvCc%3D&reserved=0>
Cypress Developer Community <https://nam04.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.cypress.com%2F%3Fet%3Dwatches.email.thread&data=02%7C01%7Cdavidw.zhang%40arrowasia.com%7Cbb8c6c45031e41384c8808d709af6da7%7C0beb0c359cbb4feb99e5589e415c7944%7C1%7C0%7C636988521372890245&sdata=v6Qu%2BzFnyPM0ADuiGi%2BCr1rL5SAo7ePt%2F1aI5Xe6f%2B0%3D&reserved=0>
reply from SananyaM_56<https://nam04.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.cypress.com%2Fpeople%2FSananyaM_56%3Fet%3Dwatches.email.thread&data=02%7C01%7Cdavidw.zhang%40arrowasia.com%7Cbb8c6c45031e41384c8808d709af6da7%7C0beb0c359cbb4feb99e5589e415c7944%7C1%7C0%7C636988521372900238&sdata=u73ZhkoLf1HcstuAF%2FI929awAS9OuxkYEAY1VveqsY0%3D&reserved=0> in USB Low-Full-High Speed Peripherals - View the full discussion<https://nam04.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.cypress.com%2Fmessage%2F202545%3Fet%3Dwatches.email.thread%23202545&data=02%7C01%7Cdavidw.zhang%40arrowasia.com%7Cbb8c6c45031e41384c8808d709af6da7%7C0beb0c359cbb4feb99e5589e415c7944%7C1%7C0%7C636988521372900238&sdata=R1t111JeTW%2BEupzoNcWRD7fPca9PgMDwA1P5PYeA76M%3D&reserved=0>
