[CY7C68013A] the led don't work
blablabla
hi guys!
I'm new here. I just bought one CY7C68013A and when i plugged in to my laptop, to check quickly if the product work but the led don't work. It is normal before installing the drivers and the other stuff or my card is just dead ? I manage to measured 5v at one point in the board and I also use the switch before someone asking.
It is a normal behavior or should I ask the reseller for another one?
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
Could you please let us know which kit did you buy?
Also, is the device enumerating and visible in the device manager? If yes, please let us know by which name is it showing up and driver details.
Mallika
It is the discovery kit and the card is not visible in the device manager. I do not feel it is gonna work anymore.
MallikaK_22
Can you please probe the voltage lines (VBUS) and check?
Can you also let us know if you are using a certified USB cable ?
Which OS are you using?
Mallika
