Recently, I have met a packet loss problem with the bulk asynchronous transfer from fpga to pc(16Mbps).
conf: bulk IN ; ept 6;  maxpacketsize = 512; slave fifo mode.
        with the data goes form 0x0000 to 0xffff as a cycle, I set the  asynchronous data get length once as 512 * 256. Data loss when the data number reach  0x8800
                                                      0x1088800
                                                      0x2088800
                                                      0x4088800
                                                      0x8088800
                                                      0x9800000
attached are the firmware and my  asynchronous transfer code.
Could you please create a tech support case regsrding the issue that you are seeing.
Also please attach all the necessary project files to the case.
sai krishna.
