CY7C68013A nand flashes check
abdullahnasir
First like received 5 sign-ins First reply posted
Hello Everyone !
I have attached Flash Nands with my Controller and am using it as a usb(MSC)  drive.
How to read/write file or data to a certain address to the nand and verify it by a fixed command over uart before enumerating as msd.
Basically the purpose here is to verify health of the attached nands
Any help would be highly appreciated.
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
Can you please explain your application better? We will be able to assist you better then.
Mallika
Hi ,
Thanks for taking interest and replying.
Well my requirement is to indicate the health of my NAND FLASHES ( 4 in my case , each of 2GB) through uart protocol to external serial terminal attached along either through uart0 or 1.
I don't want to enumerate my device as MSC  but I want to write some data at some addresses of attached nand flashes(K9F2G08U0D-SIB0 in my case) and after verifying the read/write operation sucess, I would like to print the indication serially
Kindly help me in implementing it at code level
