Hello Everyone !
I have attached Flash Nands with my Controller and am using it as a usb(MSC) drive.
How to read/write file or data to a certain address to the nand and verify it by a fixed command over uart before enumerating as msd.
Basically the purpose here is to verify health of the attached nands
Any help would be highly appreciated.
Can you please explain your application better? We will be able to assist you better then.
Mallika
Hi ,
Thanks for taking interest and replying.
Well my requirement is to indicate the health of my NAND FLASHES ( 4 in my case , each of 2GB) through uart protocol to external serial terminal attached along either through uart0 or 1.
I don't want to enumerate my device as MSC but I want to write some data at some addresses of attached nand flashes(K9F2G08U0D-SIB0 in my case) and after verifying the read/write operation sucess, I would like to print the indication serially
Kindly help me in implementing it at code level
