Hello evereone!
At the moment i am trying to implement parallel interface on CY7C68013A. And i face with such problem: how i can programming two of GPIF waveforms as one type of transers, single write, for instance. GPIFWFSELECT regester respond for this, by default, one waveform is assigned to each transfer type, but how to use it in my case i don't understand.
You can programmatically select the waveforms by assigning the appropriate value for waveform (WF 0/1/2/3) to GPIFWFSELECT register. Say for example, if WF 0 and WF1 are single write waveforsm, then
- to execute WF0, assign the SINGLEWR1:0 fields of GPIFWFSELECT register value of 00, and then trigger SINGLE WR transfers.
- to execute WF1, assign the SINGLEWR1:0 fields of GPIFWFSELECT register value of 01, and then trigger SINGLE WR transfers.
Gayathri
Gayathri
Gayathri, thanks. I just thought it is posiible to do that just initilaze some register in one time and do not change it anymore.
can u help me?? any firmware available for communicating usb and parallel interface (cy7c68013A)??
Hi ,
Refer the firmware (related to application notes) provided in the links below
http://www.cypress.com/?rID=43046
http://www.cypress.com/?rID=46029
http://www.cypress.com/?rID=39392.
Vikas.
