CY7C68013A GPIF and FIFO consulting
YaXi_4492421
10 replies posted 10 questions asked 5 replies posted
I want to use the GPIF and FIFO functions of CY7C68013A in this way:
1. Two channels of data transmission, CY7C68013 as a slave to receive data
2. The data format of each channel is: 1 clock pin, 8 data pins
3. The data rate is 9MHz
4. All data received are transferred to PC through USB
Can the above functions be achieved? Do you need any special attention if you can? Is there a example?
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
Please note that such parallel functioning of modes is not supported.
Please refer to this KBA : https://community.cypress.com/t5/Knowledge-Base-Articles/Difference-between-FX2LP-Port-I-O-GPIF-and-...
Mallika
MallikaK_22
Mallika
