        Is there any software method to reset Endpoint data buffers and byte counts
except for hardware reset?
I want to download functional some firmware to CY7C68013A over and over
without hardware reset.
I found CPU reset is NOT initialize Endpoint data buffers and byte counts.
Is there any method?
Thank you.
        Sorry, "initialize Endpoint data buffers and byte counts" means
Unarm of Endpoint buffer and byte count.
        can you tell me how can i get the firmware(CY7C68013A),thank you
        The technical reference manual of EZ-USB has clear code snippets for endpoint reset....
Download the cy3684 fx2lp dev kit... it contains firmware examples....
