CY7C68013A-56BAXC's datasheet P26 , Table 11.
XTALIN
"It is also correct to drive XTALIN with an external 24-MHz square wave derived from another clock source. When driving from an external source, the driving signal should be a 3.3-V square wave."
What are the details of the input clock specifications? Ex. Accuracy
FX2LP should be clocked at 24MHz +/- 100ppm tolerance. Please let me know if you have other questions.
Mallika
Mallika
Hello, Mallika.
Thank you for your answer.
Please let me ask an additional question.
Are there any other specifications required other than accuracy?
Ex. FX3 Input Clock Specification
Also, do you have a recommended part number?
Hello, Mallika.
But this is the details of the crystal oscillator.
I would like to know the details of the input square wave specifications.
There are no other specifics from our end to be followed apart from the ones told above.
Mallika
