CY7C68013 EZ-USB FX2 (not a CY7C68013A).
mabe_4449396
Hello!
I have a cypress microcontroller CY7C68013 EZ-USB FX2(not a fx-2LP). Can i  use last version of CyApi.lib to download the firmware hex file into the CY7C68013 RAM? (C# or C++ vesrion).
And do I understand correctly - Eclipse IDE for C/C++ Developers can be used to develop firmware for CY7C68013 EZ-USB FX2 ?
YatheeshD_36
Please use the EzMr (EZ-USB Control Panel) from the CY3681 EZ-USB FX2 Development Kit. Follow the instruction mentioned in the tutorial and user guide of control panel which can be found under help.
For downloading firmware to EEPROM please refer to KBA Programming the Serial EEPROMs on the FX2 Development Kit Board
Firmware development for FX2 is done through Keil uVison 2.
Yatheesh
YatheeshD_36
Yatheesh
