 Good day!
I use cypress CY7C68001 & FPGA. Unfortunately in windows xp it is always defined as full-speed device. I guess that was producing incorrect adjustment of the device. Could you give an example for settings  hi-speed mode? I am interested in the boot sequence registers and their values ​​for the configuration without EEPROM.
 Well, the problem turned out to be quite simple. It was necessary to do a reset 10ms, not 200ms
        Thanks for updating the thread
