I am a new user of the Cypress CY7C67300 EZ-HOST controller provided with the xilinx ML605 development kit.
In order to operate in the Host mode I need to write the firmware I suppose.
Could any of you please let me know how to go about it ? Are the tools for free ? If so could you please provide the link for the same ?
Thank you
I have double checked with our Engineers. We don't recommend the new design of CY7C67300. C3663 is the development board of CY7C67300. CY7C67300 is obsolete and EZ- host IDE is end of life. If you still want to design the keyboard with AMD reference design. We recommend you ask AMD for the help.
Kieran
   You can download reference design for Keyboard from http://www.xilinx.com/products/boards/ml403/reference_designs.htm, in which CY7C67300 acts as Host, therefore you can reuse the same firmware. Copy this folder into standalone folder and compile it. See http://www.cypress.com/?id=187&rtID=119 for software tools. Go through "Getting Starte Guide" http://www.cypress.com/?rID=14316 for more information about the device.
Prajith
 Hi Prajith,
Thanks for your post. It was really useful.
However I had a small doubt - In the xilinx files "usb_hpi_test" and "usb_printer", a bin file is read from a content in the flash and sent to the EZ-Host via HPI interface initially.
My understanding is that this is some kind of firmware which is stored inside Flash and this is being sent to the EZ-Host. Is my understanding correct ? If so presumably the bin files are specific to a peripheral and how could I reuse it for my own peripheral ?
Thank you
i'm looking for the CY7C67300 Development Softwares for linux.
Any help please !?
  We don't have CY7C67300 Development softwares for Linux but we provide Linux driver,  it  can be found in the C:\Cypress\USB\OTG-Host\Source\coprocessor\linux\drivers\usb\cy7c67300 directory after the CY3663 - EZ-OTG / EZ-Host Development Kit has been installed on your system.
Prajith
TiQu_299816
Is there another path for the Linux driver?  The path :\Cypress\USB\OTG-Host\Source\coprocessor\linux\drivers\usb\cy7c67300 does not seem to work?
Hi
I want to make it operate in the peripheral mode,,but I do not know the developement  software.Could any of you please let me know how to go about it ? Are the tools for free ? If so could you please provide the link for the same ?
Thank you
jack
        hi, i have to work on cy7c6300 development software.i don't have the software.please give me suggestioon.how to get the software.
        hi, iam new user for cy7c67300 EZ-HOST controller.i have to develop firmware code using that controller.i need cy7c67300 control supported software.please give me information,how to get.....
        http://www.cypress.com/?id=187&rtID=119 -PRJI
hai...i need to work with cy7c67300 controller.iam a new user for this controller.how would i write bootloader program for this controller and how would i built the bootloader code into eeprom.please anyone can give me suggestion.
Hi. I am using CY7C67300 in my card, When I connect my board with my PC in which I already installed the EZ-host but the driver doesn't  work. Any one have a solution for this??
MarkGrindell
First reply posted Welcome!
None of the links here work. The Cypress links are redirected to the Infineon welcome page. The Xilinx links are redirected to the AMD welcome page.
1.  reference design for Keyboard: https://www.amd.com/en/search/site-search.html#q=ml403%20&firstResult=20
Other information needs to be confirmed.
Kieran
Kieran
Thank you Kieran,
Do you have a link to the CY3663 development software and schematics?
Many thanks
I'm so sorry. We don't have that. CY3663 is the same as CY7C67300. It's out of stock and end of life too.
Kieran
Dear Sir,
On a slightly unrelated note, I have an old Cypress CY3630 development kit - but the CD that came with this is unreadable. Do you have an image file for this that I can download?
The disc is labelled "WirelessUSB LP Evaluation kit".
Many thanks
Mark
Hello Mark,
I'm so sorry. I have double checked with my manager and we don't provide that case the end of life problem.
If you still want to get that, you can contact local FAE and they may give you some help.
Kieran
