USB low-full-high speed peripherals
ReidWang
5 sign-ins First question asked Welcome!
Use CY7C65213A to replace FTDI FT232, together with a SP3485 , found in the debugging process with CY7C65213A pin13 and 14to control SP485 DIR, the chip can not achieve this function, check the chip manual, discovered that the default state for the chip is not used to control SP485, manual suggest to manually configure, but we are under Linux debugging to provide development kit, not success.
Roy_Liu
Moderator 500 solutions authored 5 questions asked First question asked
The IO of USB serial bridge series chips can be controlled by API refer to the article below:
https://community.cypress.com/t5/Knowledge-Base-Articles/USB-Serial-Bridge-Controller-Managing-I-Os-...
Roy Liu
Roy_Liu
Roy Liu
