May 09, 2020
10:17 AM
May 09, 2020
10:17 AM
Hello. The CY7C65213A is noted to be CDC driver compatible. Using only the CDC driver, can the RS485 mode be supported or is the Cypress driver required to be loaded to enable this mode? This is not clear to us from the datasheets.
Labels
09:42 PM
May 09, 2020
09:42 PM
RS-485 protocol of USB-Serial Device CY7C65213A/211A/215A is implemented in the firmware. Hence, the feature can be used/implemented using cypress driver as well as native windows/linux CDC driver.
Yatheesh
09:42 PM
May 09, 2020
09:42 PM
Yatheesh
