i have simple board with a CY7C65213-28PVXI chip on it
driver / chip vid & pid changed from the defaults, driver re-signed properly
board plugged into new PC via motherboard USB2 native port - device detected, driver installed when pointed at new files and the 2 devices ( MFG also ) appear as expected and all is happy.
unplug the cable and plug it into a different port on the same machine and only the first end point enumerates but then sits there with a code 10 error message from the driver.  possibly correlating to being in a USB 3 port now
this appears to happen on at least 2 different PCs
any thoughts anyone?
thanks
Andy
Sananya_14
Hello Andy,
-Please try uninstalling the driver and manually reinstalling it again.
- Could you please attach a screenshot of the device manager when the error occurs?
Sananya
Sananya_14
Hello Andy,
Sananya
