Does the square pad on the back side of the QFN package need to be connected to ground?
I'm playing with you design kit and want to ensure I get the design right. . .
Roy_Liu
1000 replies posted 500 solutions authored 5 questions asked
Recommend to connect to ground. The below apps note has the guidlines of designing QFN package device.
AN72845 - Design Guidelines For Cypress Quad Flat No-Lead (QFN) Packaged Devices | Cypress Semicondu...
Roy Liu
Roy_Liu
Roy Liu
YangyangC_06
Usually the EPAD of an IC will be connected to GROUND of the PCB board. You could also check the Cadance PCB file if you have installed EZ-Serial SDK.
Thanks. The doc helped a lot.
