Does the square pad on the back side of the QFN package need to be connected to ground?
I'm playing with you design kit and want to ensure I get the design right. . .
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
Recommend to connect to ground. The below apps note has the guidlines of designing QFN package device.
AN72845 - Design Guidelines For Cypress Quad Flat No-Lead (QFN) Packaged Devices | Cypress Semicondu...
Roy Liu
Roy_Liu
Roy Liu
YangyangC_06
750 replies posted 500 replies posted 250 replies posted
Usually the EPAD of an IC will be connected to GROUND of the PCB board. You could also check the Cadance PCB file if you have installed EZ-Serial SDK.
Thanks. The doc helped a lot.
