hata_3396041
Level 4
Level 4
First solution authored First like received 50 questions asked
Hello
Please tell me about Initial settings of CY7C65211A.
1.Is there a format for customers to list specifications?
 (If you have something like USB-PD)
2.Is there a way to write initial settings to CY7C65211A?
 (Is it possible to deliver a device with the customer's initial settings written?)
If 2 is possible please tell me the necessary information such as configuration files.
hayato
HirotakaT_91
25 solutions authored 10 solutions authored 5 solutions authored
Hi Hayato,
Kindly check USB-Serial Bridge Controller FAQs – KBA224054(JA)​ for understanding these queries.
A1. I am not clear what is the expectation for the customer. .cyusb file format can use for configuring these USB-Serial products.
A2. A customer should do it or ask it to programming manufacturer.
Altough it depends on the amount of mass-production, typically, our answer is No. For more detail, contact Cypress FAE or Sales.
Hirotaka Takayama
HirotakaT_91
Hi Hayato,
Hirotaka Takayama
