Hi~
I designed a USB-I2C bridge in school with reference to the datasheet of CY7C65211,CY7C65211 is set as the master and a temperature sensor is set as the slave.
In "USB-Serial Configuration Utility", I successfully set up its configuration(program succeed).But I don't know how to send the control commands and read the data of the temperature sensor in Windows system. Please kindly tell you in detail which software to download and learn.(‘"TEST UNYILITY"appears to be able to test only data)
thanks.
You can perform I2C communication between USB-Serial and sensor using an user application. Kindly refer to the example source codes present in the following path: C:\Program Files (x86)\Cypress\USB-Serial SDK\examples\usbserialexample
USB Serial SDK can be downloaded from here .
Mallika
Mallika
hi Mallika
Really thanks for your answer. And I only have one computer and a circuit board with CY7C65211 and the temperature sensor. I downloaded the USB Serial SDK and the parameter was successfully configured.But I'm still not sure how to use the source files to perform I2C communication between USB-Serial and sensor. and “USB-Serial Configuration Utility”can only configure manufacturing settings and options for Cypress USB-Serial devices. but can not set the slave adress and other control commands of the temperature sensor
In the example description,it says that USB-Serial DVK is needed.Does that mean I also need to buy a USB-Serial DVK to perform I2C communication?
Really thanks!
