The PC host  sents USB Request Block to CY7C64713,Firmware How to response the URB?
  Bus Hound 6.01 capture:
55.1            URB    48 00 09 00  00 00 00 00  10 0c 8d 89  20 00 00 00  BULK/INT XFER       4us         1.2.0
                                 0c 44 9f 86  03 00 00 00  08 00 00 00  00 00 00 00                                  1.2.16
                                 a0 c4 af 86  00 00 00 00  ff ff ff ff  0d f0 ad de                                  1.2.32
                                 f0 f5 e7 87  00 00 00 00  00 00 00 00  00 00 00 00                                  1.2.48
                                 00 00 00 00  00 00 00 00                                                            1.2.64
Please refer the link  http://msdn.microsoft.com/en-us/library/windows/hardware/ff537056(v=vs.85).aspx to know about the URBs.
If the uRB is related to OUT endpoint then in the device there should be an OUT endpoint and the fimrware inside the CY7C64713 should have enabled the endpoint and it can commit the data to peripheral domain, it can edit ok it can skip the data.
For more details about the firmware handling refer the technical reference manual
VIkas.
