 Hi there,
I have been reading a lot but get a doubt on USB HID data transfers. I'm sending data to the CY7C64215, but the problem is sending more than 8 bits data.
The function i'm using is USB_bReadOutEP(...), i know this function reads and writes on an array of bytes.
My question is, on report I can put a report size about 10 bits, how can i read 10 bits at once?. On PC side, when i declare the report size of 10 bits C# shows me more "byte" fields.
The other question, in case i want to send ADC data (14 bits), to the PC, i was thinking about a report size of 14 bits, and hoping to get 14 bits on the PC side. The solution i worked out was sending the first 8 bits, and then the other 6 bits, concatenate. This is the form it should be? or is something i'm missing?.
It dont seems like concatenating 8 times for getting a 64 bits data. It's there a form of getting the 14 bits at once?.
Sorry about the question, i search on forums but dont found anything about reading more than 8 bits data.
Thanks in advance!
    P.S. The buffer size is 8 bits, does it changes when i put a report size of X bits?. Thanks.
Could you please create a tech support case to get help on this.
sai krishna.
did you find how to send the data more than 8 bit to pc from USB HID device?
        Hi, Please find the project attached.This project sends two bytes to host using feature report. Hope this helps.
 did you solve your problem?  It is probably a reportsize or reportcount issue in the HID report you fix in the HID wizard
No, I am still seeing the issue.
Please check the forum post @ http://www.cypress.com/?app=forum&id=167&rID=89004
Hope this helps.
-Anandh
