Thanks for answering my post, I have attached my project, I did the example Project that is on USB Module datasheet, I have proved this project in W7 and it didnt work either, and I prove either in W vista and it worked corectly, but I am interested in doing this application in my W8.
hello I'm sorry for a lot of post empty but I can´t I attach my code i will try to submit with mozilla
I can't attach my code I'll try again, How can I do a Tech support case?
Go to Cypress.com->Support & community -> Technical support -> Create a case
Hi ,
Please find an example project attached.
Program your device with the hex file and connect it to your PC.
It will enumerate as a HID class device and the mouse cursor will start moving from the left to right and right to left and so on.
You can use this project as reference to build your project.
If you have problems in creating a case, you can email your firmware to ankc@cypress.com
-Anandh
Hello
I made the same project, I proved the code that you attached, and appear this error "A request for the USB device descriptor failed." code 10
Thanks for your reply
Is this problem specific to Windows 8 ?
Can you please test it in Windows 7 and XP ?
Also please provide me the details of your hardware.Please share your schematics.
If you have problems in attaching it here, email me directly ankc@cypress.com.
-Anandh
Hello I proved In 2 laptos with w8 and my computer with w7 and it doesn´t work, but when I proved in windows vista it work perfect, I use the configuration in the show in the datasheet i Only change the Resistance by 220 (In the datasheet is 240) and I use .1uF for the capacitor
I attached The image of configuration
Please use 22 Ohms instead of 240 Ohms and test.
It should work.
Hello Sorry for the late reply
I changed the resistence for 22 ohms and now works perfectly but why afect the value of resistence?
🙂 thank you Anandhakumar
Resistance on the datalines matter. It can increas the rise\fall time of the signal and can attenuate the signal as well.
-PRJI
